05-22-2017, 07:57 AM #1
- Feb 2015
- Brazil
- 26
Upgraded to 1.1.0 RCBugFix. Is my UBL working?
Upgraded 1.1.0 bugfix from my original (early 2015) version of Marlin. Made sure everything was working fine before moving on.
Carefully went over the configuration.h as much as possible, comparing values and trying to figure out the new (much simpler once you get it) variable names.
Now it seems I've got it working, UBL and all, I just don't really know how to use it.
Should I change my gcode startup scripts to G29 L0 to load the tables before printing? Should I run G29 P1 often? How does one go about using it?
Also I don't get it why the printed doesn't "remember" the table after a reboot, even after using M500 after a G29 P1. Or does it?
This is my current bed topography (Z probe is a micro switch on a servo)
READ: (0,9) (9,9)
READ: (1,217) (225,217)
READ: . . . . . . . . . .
READ:
READ: 0.165 0.110 0.108 0.097 0.070 0.080 0.095 0.085 0.080 .
READ:
READ: 0.108 0.097 0.070 0.047 0.072 0.063 0.060 0.050 0.063 .
READ:
READ: 0.065 0.055 0.047 0.065 0.050 0.050 0.052 0.043 0.045 .
READ:
READ: 0.030 0.030 0.030 0.045 0.027 0.032 0.027 0.015 0.005 .
READ:
READ: 0.027 0.037 0.030 0.052 0.030 0.037 0.035 0.003 0.015 .
READ:
READ: 0.040 0.045 0.010 0.040 0.032 0.030 0.027 0.010 0.017 .
READ:
READ: 0.050 0.023 0.045 0.050 0.037 0.010 0.023 0.035 0.052 .
READ:
READ: 0.072 0.057 0.060 0.068 0.045 0.075 0.080 0.075 0.065 .
READ:
READ: [ 0.080] 0.072 0.052 0.050 0.070 0.077 0.125 0.092 0.072 .
READ: (1,1) (225,1)
READ: (0,0) (9,0)
READ: ok
BTW Thanks Roxy, great work!!!
EDIT: This is my Configuration.h M48 gives a solid "Standard Deviation: 0.001225"Last edited by Renfro; 05-22-2017 at 08:18 AM.
