Results 1 to 10 of 22
01-01-2015, 05:05 PM #1
- Dec 2014
- 14
Build up on corners and curves causing prints to fail.
Printing things with a large base has been no issue for me yet, but I cant seem to print things with a small base, even with a raft. I'm new to 3d printing, and I can't seem to findout why its doing this. Currently I'm printing at 50mm/s and 80mm/s travel. 230 extruder temp, 112 bed temp. I've tried faster movement, 80mm/s for both feed and travel. I tried playing with the bed temp as well, moving it up to 115 and 120, both with the same result.
https://drive.google.com/file/d/0B_O...ew?usp=sharing
The extruder ends up catching the build up and pulling the print off the board.
01-01-2015, 07:37 PM #2
ABS or PLA? I have been running all my ABS at 90c lately with machine enclosed.
01-01-2015, 09:07 PM #3
- Dec 2014
- 42
does it seem to help running the lower bed temp? What differences did you notice between 100 and 90?
01-01-2015, 10:16 PM #4
- Dec 2014
- 14
01-01-2015, 10:17 PM #5
- Dec 2014
- 14
I'll give 90c a shot.
01-02-2015, 12:51 AM #6
No problem. On 3/16" Borosilicate Glass (Pyrex), generally use glue stick. Some times use abs slurry.
01-02-2015, 02:32 AM #7
- Dec 2014
- 14
tried the 90c bed temp and still got the issue.
a more severe case.
https://drive.google.com/file/d/0B_O...ew?usp=sharingLast edited by bodoo; 01-02-2015 at 02:55 AM.
01-02-2015, 03:03 AM #8
Could be a lot of things. What software are you using to prepare prints? Filament density calibrated? What retraction settings? Is the printer fully enclosed?
01-02-2015, 12:28 PM #9
- Dec 2014
- 14
I'm using replicator g to prepare the g code, I'm not sure about retraction and filament calibration though.
01-02-2015, 12:33 PM #10
any chance of a photo that's more print than hand.
Apart from a slight curling can't see any obvious issues. But then you can't really see much of anything, printwise.
Also try using makerware 2.4.
Rep-g just has too many issues to bother with :-)
