Results 11 to 20 of 21
Thread: Ideas for new User designatons
10-10-2016, 09:44 AM #11
10-10-2016, 01:21 PM #12
- May 2016
- SE Wisconsin
- 206
They should be set more along the lines of how much posting you do rather than the titles like "engineer" and stuff.
I am not an engineer. I should not have engineer next to my name. (yet, give me a few more years)
Initially that was somewhat misleading to me, because when I see engineer next to a name I assume they can answer my question. Here though, you can have a few thousand posts of drivel if someone is careful enough to not break rules, and that title would imply that they have a clue while in fact being completely false.
10-10-2016, 01:22 PM #13
- May 2016
- SE Wisconsin
- 206
And since the last post was 199, this will bump my title to engineer in training without contributing anything at all to the forum. Though strangely this useless post winds up being on topic here in this thread. Nothing "engineer" about this.
10-10-2016, 05:03 PM #14
- Oct 2016
- Central Wisconsin
Here I am - first post and checking in on this thread! I don't always look at levels, but on a tech site like this, the relevance is (hopefully) there.
Why not go with Levels? It's kind of a gamer thing, but you could "level up" as you post.
That being said, Ama-fessional Molder made his point well with his last post.
10-12-2016, 08:45 AM #15
By levels, what exactly do you mean? Can you provide an example?
10-12-2016, 01:33 PM #16
10-12-2016, 01:34 PM #17
10-12-2016, 05:43 PM #18
- Oct 2016
- Central Wisconsin
Levels
Something Like:
Level 1 - up to 50 posts (+1s would count)
Level 2 - 51-100
Level 3 - 101-150
Level 4 - 151-200
etc.
Of course you would choose how many posts are realistic or meaningful in terms of numbers. You could even raise the number required to attain a level as the levels get greater (higher).
Not a fun descripter, but nicer than "Nube, Beginner, Lowlife," whatever.
Most forums I'm on simply have the number with no ranking.
10-12-2016, 06:40 PM #19
- May 2016
- SE Wisconsin
- 206
Oh boy. Then my posts can be experience points!
10-14-2016, 05:02 PM #20
- Apr 2015
- Northern Ohio
- 198
I also agree. Just because you post a lot doesn't mean you advice is relevant or even accurate. I have seen a lot of that here with high post counters.
The post counts should be removed all together and replaced by a rating system where the peers rate the replies and posts by the member. Many a newbie has been led astray or discouraged by bad advice. This applies to most forums not just this one. I have been a mod and admin on other boards on differerent topics and seen the post count wars.
I would also encorage a bio section where users will need to post a short explanation of their backround, goals, and experince level before posting on the main board. Then other members can know how to better answer thier questions.Last edited by Todd-67; 10-14-2016 at 05:07 PM.
New member with print issue
