It is weird cause things will be going fine for a few prints and then the next one results in the servo over extending. I then change the config file and a day or two goes by of good performance and then out of the blue the servo will under extend and I have to go back into the config file to change it to the previous setting.
Here is what currently happened. Two days ago I had to reset the config file to a new servo angle. I printed a model and things went well. Power off. The next day, I printed a file and it worked well. Power off. This morning, I again printed a file and it printed fine. Without shutting the machine off, I printed another copy and the servo under extended. This morning it printed fine! I did not shut off the machine.
I had to reset the servo angle to get the probe to extend correctly. I am going to test this out by now running a print and then run another print without shutting the power off.
Configuration.h
