Originally Posted by Stijn There are a lot of parts inside the object. This would indicate that an assembly, or part thereof, was exported as an stl and not a part. Either: 1) Re-export only the part you want or 2) Use a boolean function to unite the parts you want into one single part and then re-export.
View Tag Cloud
Forum Rules
New member with print issue
