Originally Posted by
printbus
Ah. You guys are talking about the M5 bolts and the nut plates? I know I had a problem on my i3v with the M5 bolts bottoming out, evidenced by a ring from the bolt being cut into the far side of the channel in the extrusion. I solved that by filing off the machining ridge left on the threaded end of the bolts or by adding a washer under the bolt head.
