Thread: Make walls thinner on object?
08-19-2016, 10:14 AM #1
- 441
I have this plant pot that I've been trying to find a way to fix this issue. When it prints, it prints as 2 walls going up. I'm trying to get the model to print with 1 wall going up, like a vase mode. Even with vase mode enabled in S3D it still prints 2 walls. If you run the file through you will see what I mean. Basically trying to make it print 1 wall the entire way up to save time and materials. You can get the planter here..
http://www.thingiverse.com/thing:698864
08-19-2016, 11:07 AM #2
well before geoff jumps in - try makerware :-)
s3d just won't print single walls.
makerware will.
08-19-2016, 12:52 PM #3
I have printed many single walled items using S3D. You simply change the outer perimeter shell to 1.
I think the issue is more the model and hardware combination than the slicer. The model was created with a thicker wall than your nozzle so the slicer is just filling in what it thinks is the total model. If I slice the model linked in S3D with a .4, it wants to do two shells. If I punch in a .8mm nozzle, it does just one shell.
08-20-2016, 11:29 AM #4I have printed many single walled items using S3D. You simply change the outer perimeter shell to 1.
08-20-2016, 11:36 AM #5
- 441
Yeah, I figure the problem is the walls on the model are too thick. If I change it to 1 outer perimeter shell, it's still doing 2 walls with a single shell. I want to get it down to a single wall, I'd prefer to do with 2 shells, but doing with 2 shells is currently doing 2 walls, and 2 shells, which takes a substantial amount of time more. I believe the problem is the model being too thick, that's why I want to thin it out. Other than trying Makerware I still haven't figured it out :P But using Makerware just is going to create more problems because I have a lot of customization in my prints.
https://i.gyazo.com/c73e98d453baa1f8...ea46986d97.png
For some reason my picture isn't showing up on here.Last edited by Bassna; 08-20-2016 at 11:42 AM.
08-21-2016, 11:06 AM #6
lol you were away when someone decided to remove all forum attachments and not allow any more.
Nobody has ever said why.
That's one complicated vase - looks like a strawberry planter.
08-22-2016, 07:58 AM #7
