Results 1 to 10 of 16
08-13-2016, 11:01 AM #7
- Jul 2016
- Pennsylvania, USA
- 255
Hi
If you switch from the "stock" MakerFarm Marlin to something newer, be prepared to spend some quality time getting the config right. You are going up quite a ways in terms of Marlin versions. It's well worth doing, just don't try to do it without digging into the config's. While you are in there, set up the X,Y and Z limits to correspond to the ones on your actual build.
Bob
