Results 2,561 to 2,570 of 4110
07-28-2016, 08:48 AM #2561
- Mar 2016
- 52
Hey all,
I installed Simplify3D yesterday and noticed that the standard Qidi profile is doing a reasonably good job. Problem is that I am once again faced with non-accelerated moves, especially in small loops and features. My machine is "shuddering" like crazy! I read that someone went from Qidi 7.8 to Sailfish 7.7 and was able to mitigate all of this shuddering simply by flashing the official firmware. My thoughts are that Qidi is using a VERY dated copy of Sailfish (not a 7.7 fork), that might even be slightly broken...
I am going to attempt to flash to Sailfish 7.7. Can anyone recommend a USBASP ICSP Programmer that will do the trick?
07-28-2016, 09:03 AM #2562
Do not try it I know of no one that has successfully loaded the official version of Sailfish on Qidi Techs that come with there own version of Sailfish 7.8.
You will brick your board.
If your having acceleration problems there is something else going on. Do you have acceleration turned on from the Qidi Tech screen menu.
Also use the startup script found here with S3D http://3dprintboard.com/showthread.p...Startup-Script
07-28-2016, 09:25 AM #2563
- May 2016
- Annapolis, MD
- 523
07-28-2016, 09:45 AM #2564
- Jun 2016
- Oklahoma
- 904
07-28-2016, 09:50 AM #2565
- Mar 2016
- 52
The betterblock printed fine without any shuddering in S3D... Really no complaints there. I then sliced a high polygon model with many small features and the printer shuddered like crazy while printing the small details, ultimately completely ruining the print... Its strange, because the raft printed perfectly, but the moment it started printing the models first layer, the printer completely freaked out.
In regards to bricking the qidi controller: did the people that bricked their controllers set the fuse bits properly? Did they use the atmega2560 bootloader that dan newman has on github. I dont see how you can brick a board if you simply use the right settings. An atmega2560 and atmega8u2 are what they are... As long as you use the right settings it should work.
My worry is that qidi used a very old version of sailfish that did not properly navigate small features and small loops (especially on high polygon models)... It could also be that sailfish firmware itself has issues with applying acceleration to *some* small features... And we only rarely hit the limitations of the firmware.
All my firmware settings are good, and acceleration is turned on. My jerk setting is at 7. I could reduce it further, but i doubt that will fix it.
07-28-2016, 09:57 AM #2566
- Jun 2016
- Oklahoma
- 904
So I have ordered a nice digital "dial" indicator to use for bed leveling. Anyone have suggestions for a method for indexing the gauge to a zero bed to nozzle clearance? I figured once it is zeroed then you could not only level but set the gap between the bed and nozzle.
Thanks for any ideas!!
07-28-2016, 10:22 AM #2567
I have no idea what your printing. Have you had some one else try printing it?
As far as the info on Gethub you would need to get a hold of Dan for that info. Like I said I have not personally heard of anyone successfully changing the newer Qidi Tech Firmware and several have tried.
07-28-2016, 10:27 AM #2568
I have a dial indicator and tried it and found a piece a paper is still easier, faster and accurate enough.
Even with the Dial indicator you will still have to check that the nozzle heights are the same with a piece of paper.
07-28-2016, 10:33 AM #2569
- Aug 2014
- 627
07-28-2016, 10:45 AM #2570
- Mar 2016
- 52
The model i was printing was admittedly quite "raunchy". Its called girlwatchstars or something like that. I can upload it when i am home, so you can try printing and let me know if you experience the same issue.
I think i will get in contact with Dan and have him give me his take on the problems i am seeing. I am sure he will admit if its in fact a limitation of sailfish, or if it has been fixed in later versions of sailfish.
