Results 2,311 to 2,320 of 4110
07-11-2016, 09:31 PM #2311
- May 2016
- Annapolis, MD
- 523
07-12-2016, 05:50 AM #2312
- Jun 2016
- Oklahoma
- 904
Yea the test cubes show a subtle difference and more to illustrate how the outer surface changes when internal parts change.
I did another test last night and I think the only big change was dropping the extruder temp to 220 and bed to 100. I was doing the bed at 110 and then down to 100. The part came out pretty good but then I realized I didn't have support turned on. Running another today with support to see what happens.
07-12-2016, 05:54 AM #2313
- Jun 2016
- Oklahoma
- 904
07-12-2016, 09:15 AM #2314
- Feb 2016
- 360
So, my X axis belt is getting pretty loose.
Was gonna tighten it this morning before I started the days prints...then I decided not to. Gonna see just how far it will go before the slack starts to create issues with how it prints. Right now you can reach in and (with no force at all) make the 2 sides of belt touch.
07-12-2016, 09:16 AM #2315
- Feb 2016
- 360
07-12-2016, 09:30 AM #2316
One thing to try is get some 4mm set screws and thread them into the ends of the xend plastics. There are little holes there, don't tap them, just use a good wrench and let them self tap. This will do 2 things, 1. tighten up any slop in the gantry, and 2. it will tighten the X belt some. Don't overdo it with the set screws, just snug them up and try to do it evenly on all 4.
07-12-2016, 10:08 AM #2317
- Jun 2016
- Oklahoma
- 904
07-12-2016, 10:09 AM #2318
- Jun 2016
- Oklahoma
- 904
07-12-2016, 10:33 AM #2319
- Feb 2016
- 360
07-12-2016, 11:14 AM #2320
Actually on one of my machines there wasn't any adjustment room left to move the stepper to tighten the belt. Plus the set screws solidify the gantry since the rods kind of float in the plastic pockets. It really isn't that complex, the holes are already there and they fit 4mm set screws perfectly.
On most printers you can move the gantry back and forth (L&R) since it is just kind of hanging there in the plastic. This gets worse when the machine gets hot and the plastics soften a little. This is one of the main causes of ringing.
