Results 1 to 10 of 4110
06-28-2016, 08:18 PM #10
- Feb 2016
- 360
I most certainly would.
Even for normal material (ABS, PetG, and PLA that is) I have noticed far less issues steming from feeding material since printing and installing these parts.
I have the stock large-tooth gear from Qidi still running on my left side and a low-pro gear on my right side. Both sides are running the feed assembly I linked. Also I changed spring on feed arm for the right side, using same length spring with just a tad less tension. Still enough push to feed great, but keeps soft stuff from getting choofed-up.
These are the only 2 feed gears I have tried so far.
