Results 101 to 107 of 107
06-01-2016, 01:25 PM #101
- Jun 2016
You mentioned you want them slightly different heights, is there a specific one you want to be higher than the other?
Currently I'm printing with my right extruder (Which according to the FF instructions is the one you're meant to use when levelling the bed) but the left nozzle is definitely is very VERY slightly lower and keeps catching my prints. Only very lightly, but it's enough to pull the odd bit off the bed if it's not stuck down well.
Is this that the nozzle is out of whack or my levels or my settings, or just that my adhesion isn't good enough?
06-02-2016, 10:11 AM #102
- Jun 2016
08-29-2016, 01:05 AM #103
- Aug 2016
Hello there,
after i read all post i now really wondering.
I got my FFCP a month ago and now have to calibrate my nozzels becaus on is off by 1mm. As the pictures from
SL666 in Post #6 tell me, i suggest having the same setup.
But if i remove all the stuff around the aluminum bar and losen and remove the setscrews (lil black ones) my throats wont come lose.
It's not that i didn't tried. First gentle twisting and pushing/pulling with my wrench and fingers later going on somewhat rougher but even holding on to the aluminum bar with pliers and turning the damn thing with the wrench i didn't came out nor in. The only thing it does is twisting and that requires an amount of force that can hardly be well.
So can anyone please tell me what i am missing?
Thanks in advance.Last edited by Detzi88; 09-03-2016 at 04:15 AM.
01-02-2023, 09:11 AM #104
- Jan 2023
DSCN7257.jpgDSCN7253.jpgJust so you know the turbofan duct is trash. I found a way to fix this on Thingiverse. (I didn't make it) (Please excuse my terrible picture quality)
01-02-2023, 09:20 AM #105
- Jan 2023
uggggggggggggggggggggggggggggggggggggggggggggggggg gggggggggggggggggggggggggggggh
Hi, I am new here and I literally just got my printer yesterday, and I have a problem. When I use FlashPrint, I set my preferences to "Left Exturder". But it starts printing (Or trying to print) with the RIGHT exturder and vice versa. I spent like an hour trying to figure it out. I am not sure if it falls into this forum, but why not.
01-12-2023, 06:30 PM #106
- Jan 2023
01-23-2023, 04:34 AM #107
- Nov 2022
- 18
Also, you can go to File/Preferences and set the preferred extruder to Left so it will always default to the Left extruder.
