Originally Posted by
DrLuigi
I aint sure if you can do this with Kisslicer or Slic3r but with Cura i do know that you can go to the advance tab and typ at (Cut off object bottom) to your prefered length,
This way you can type for example 34 (downloaded your file and that seems to be the best length to type in) and it will only print the upper part that you want.
