Results 1 to 10 of 19
05-03-2016, 09:07 AM #4
- May 2016
- 7
Ultimately I am looking for an alternative to the Stratasys PolyJet Process using DigitalABS (due to the extreme expense of the Stratsys printers).
I will be using the printer to produce injection mold tooling for prototyping.
For that reason I need to be able to produce 3D prints having very high density (low porosity) and high melting temps.
The plastic also must be a thermoset material so that it will not interact with the thermoplastic injected into the mold.
I believe SLA is my best bet, but wanted to tap the collective knowledge of this community first.
This is a good question as well. I would like to know the post-cured melting temp of the UV resins used for SLA.
Looks like 3Dsystems make a producte that when post-cured and heat treated can achieve a Heat Deflection temp of 513°F+
http://www.3dsystems.com/sites/www.3...uestone_US.pdf
