Results 1 to 10 of 15
04-26-2016, 09:01 PM #15
OK. If changing the EXTRUDE_MINTEMP doesn't cut it, there are some options. The rest of the post goes into the gory detail on what I learned. Any readers running the dacb Marlin fork from late 2014 should take note - you already have a gcode means to change the extrusion minimum temperature threshold. That's not documented in the reprap gcode Wiki, so finding that was a bit of a surprise.
Marlin has a pretty slick means of building the LCD menus. It's really easy to change the order of menu items or to add new rows to menus. IIRC, menu rows are essentially a single row of code that specifies fundamentals like the menu text, the variable name to be adjusted, and the adjustment step size. Yesterday before posting that a menu change should be possible, I glanced at the Marlin baseline I had last used a year ago and verified that the EXTRUDE_MINTEMP constant is in fact copied into a variable, which it was. FWIW, the variable name is extruder_min_temp, and the initialization occurred in file planner.cpp. So, I figured it should only take that one line of code to add the menu item to tweak it.
Today, to test the change (before I had actually made it), I hacked together a 12V power supply, my old MEGA2560 & RAMPS, LCD, a thermistor, and a stepper motor connected to the extruder stepper driver. Downloaded Arduino 1.0.6 specified by MakerFarm. Then I went to the firmware download link provided by MakerFarm to revise the code. No extruder_min_temp variable in the code. The threshold check just uses the EXTRUDE_MINTEMP constant directly. Huh?
MakerFarm has never been assertive as far as updating their baselines. When I shelved Arduino/RAMPS over a year ago, I was using the late-2014 baseline dacb had put together and documented in thread Marlin firmware fork for MakerFarm i3v w/ auto bed level & Roxy's enhancements. Turns out that the "current" MakerFarm baselines are from before that.
So why does this matter to the extruder minimum temp threshold? Here's the good part for those running the dacb fork. Somewhere between early 2014 for the MakerFarm firmware baselines and the later Marlin fork dacb provided, the M302 cold extrusion gcode command support was expanded to include the ability to set the minimum threshold temperature by adding a parameter prefaced with S. For example, sending the printer M302 S100 sets the extruder minimum temperature threshold to 100 degrees C. Maybe this is one of the Roxy enhancements - IDK.
I did go ahead and test my printer hack-up and verified the S parameter on M302 works.
Various options are on the table at this point. MattStrike could just keep changing the EXTRUDE_MINTEMP constant when he wants to run the low temp waxy filament. He could migrate to the dacb fork and pick up the ability to tweak the setting via gcode. He could wait for a bit and see what happens with the upcoming new Marlin release, and determine whether the M302 parameter support is in that new baseline. Another option would be to modify his current (albeit dated) Marlin baseline to replicate the gcode support for the M302 S parameter. The current usage of extrude_min_temp is private to planner.cpp, and that may have some ramifications to adding a LCD adjustment for it.
Now y'all know more than you probably wanted to.Last edited by printbus; 04-26-2016 at 11:20 PM.
