Results 21 to 25 of 25
07-28-2015, 03:02 AM #21
- Jul 2015
- 20
Depends on what you printer. Actually 1 kg of filament can make a lot of prints.
But, it feels different when you use different volume printers.
One of my friends got a Z18, and a Mankati or Mankato printer, both them pretty big.
he's more likely to print big things with them, so it feels filaments runs out more quickly with big printers.
07-30-2015, 09:30 AM #22
Different slice setting tendency will lead to different results.
If you often print with solid infill objects, you will have a higher filament consumption.
09-23-2015, 01:26 AM #23
How Far Does 1 KG of Filament Go?
It's the total weight of the Filament not the specific length of the Filament. As Filament is the blood of your printer and it is very important to use right type of filament.Filament generally comes in 1Kg spool. We can create upto 100 pieces of chess with 1Kg roll os filament. One roll of filament can create approximately 200 keychains. One roll of filament can print approximately 98 phone cases.
04-25-2016, 07:36 PM #24
- Apr 2016
- 6
Here's a video that goes into quite a bit of detail on filament weight, densities and what print settings will influence how long a spool can last: http://www.cubicity.com/blog/filamen...one-1kg-of-pla
04-26-2016, 07:12 PM #25
- Aug 2015
- 256
1kg of filament is 330m.
