Results 1 to 10 of 68
04-20-2016, 02:22 AM #36
- Apr 2016
- 30
Hello hello people. My name is William. I recently acquired a Makerfarm i3v 12" from a friend of mine. Mainly wood frame, with aluminum for the sliders. I believe it's setup with a Wades extruder. Currently has an e3d hot end with a 0.4mm nozzle and prints using 1.75mm filament. I got it knowing everything needed to be calibrated and tweaked. It's got the ramps 1.4 board instead of the Rumba(i have that one too)
My issue at hand, and I'll drop a not in the proper area, is, getting the Z axis setup properly. It's got a servo and microswitch for the ABL and, the marlin 1.0.3 firmware is saying the z-offset is 2.6 . when I print using something like Slic3r, it prints pretty close to correct, as far as starting height. Using Simplify3d, it's all kinds of wrong.
Off to do some research!
