Results 1 to 10 of 4110
04-18-2016, 08:59 PM #11
- Aug 2014
- 627
Ahhhh, see when I print ABS I stick it to 110c and leave it at 110c else it comes off. I wish I had a way to lower the temp gradually but not even S3D does that easily (you would think I wouldn't have to have a lot of profiles for such an easy task in S3D) as I always wanted a way to tell these slicers to lower the temp from layer 1 to say layer 5 or 7 gradually not all of a sudden at Z layer. I only lower the temp on PLA as I start at 60c and lower to 50c.
On the bed is that Kapton I see on it? I will McMaster a 6x9 glass (or 8x10 using the mod though if I did that I would attach a thin layer of Aluminum as a heat spreader so edge to edge gets warm).
While I am thinking about all of this I sure wish these slicers allowed us to get the bed to X temp and wait X amount of time before continuing that way the temps are more uniform when the print actually starts.
