Results 11 to 17 of 17
03-05-2016, 11:30 AM #11
- Mar 2016
In 3dsmax, voronoi tessellation it's literally just one or two steps. In Blender, it's a little more tricky. Rhino you need a plugin called Grasshopper, and some mathematical knowledge. So I think it just depends on the application.
03-10-2016, 10:49 AM #12
given the cost of 3dsmax - you might be better of spending 3 hours working through the process in meshmixer :-)
04-18-2016, 09:55 AM #13
- Apr 2016
first picture
[QUOTE=jjb;82375]Hi all.
I am very new to 3d printing but am very eager to make a few things.
I have only been playing around with TinkerCad.
What types of program do I need to make a mold like this?
https://img1.etsystatic.com/020/0/81...05703_8xcg.jpg
The exact and easy to use (once you get over its quirks) program to make molds like in the first picture is a freeware called eXtrudy.
04-19-2016, 05:51 AM #14
I use Blender for printing Vertex conversions, which is your second picture.
I remove all faces from the model and keep all edges. I extrude all the edges in one hit, usually in the up/down direction depending on the model, sometimes some manual work needed to extrude more of the edges. I then literally hold ALT, right click the edge loop, press F for fill and repeat that around the model. There is probably an automated process but it takes me about 10 minutes to strip a low poly model back to it's frame work and then solidify the framework. There are programs that do the so-overdone "voronoi" pattern with holes all through it, but it's been done so many times and running a script on a 3D model and saying "look what I did ma!" isn't really something to be proud of. Doing it yourself is the best way I will always say.
The tricky part is making sure the geometry doesn't exceed a certain degree, ideally no more than 40' so you can print without support. Removing support from geometric prints is a pain in the butt, it really is.
Aint that the truth... I refuse to buy Adobe, they charge Australians nearly 3 x the price. Why? our location.
We're downloading it.. not posting a 2kg package of manuals... why charge so much more for another country? I can use a VPN and buy it off them for the U.S price... but I prefer not to at all when they practice such cruddy business tactics. My money they will not get.Hex3D - 3D Printing and Design http://www.hex3d.com
04-20-2016, 02:40 PM #15
12-03-2017, 06:42 AM #16
You can use Fusion 360 as well for 3D modelling. It has a Voronoi Sketch Generator app.
12-03-2017, 03:37 PM #17
- Oakland, CA
- 935
Don't bother learning how to use the 123D apps; Autodesk discontinued them some time back, and since they were cloud-based, they no longer will work. I guess TinkerCAD is still functioning, though.
Please help dial in my printer
Today, 11:02 AM in Tips, Tricks and Tech Help
