This might be misleading, however this is still an excellent scanner that captures excellent results. If you are not happy with it then best to get a refund. If the angle was wider, then the capture detail would be less.
I agree, it's by far the best non-industrial scanner on the market. I've tried several and this one knocks the rest out the park.
New member with print issue
