I have sent the seller a question whether the pump listed is the same as pictured, and can it run on 12 VDC at 1/5 the flow rate.
No, the pump is NOT as pictured. It is a 12 VDC pump with 500 ml/min max flow rate. It has 3 rollers on the rotor. I have asked the seller if he has any more of the 24 VDC pumps left... I will let you know what he says.
