Results 691 to 700 of 4110
03-24-2016, 07:29 PM #691
- Feb 2016
- 360
03-24-2016, 07:41 PM #692
- Jan 2016
03-24-2016, 07:43 PM #693
03-24-2016, 07:51 PM #694
03-24-2016, 07:51 PM #695
- Jan 2016
Maybe this will help illustrate some of the issues I'm having. The Black model(PETG) prints fine until it gets to the "stack" and then it seems to go off the rails. The White model (ABS) is almost identical and holds it's shape in ABS. Would retraction help keep the stack vertical and smooth or is there something else you would suggest I alter in the settings?
20160324_205008.jpg. 20160324_205020.jpg20160324_205042.jpgLast edited by Vansmak; 03-24-2016 at 07:59 PM.
03-25-2016, 12:15 AM #696
- Feb 2016
- 96
Did you guys need longer screws for either end of the cable chain? What size/type?
03-25-2016, 12:51 AM #697
- Mar 2016
I just got my QIDI Tech I 3 days ago and today I noticed a problem I hope someone can help me with.
Today I was printing and noticed the left extruder kept hitting the print. I re-leveled and check everything and now when I start a print the head will start on the plate but will move too far left and hit the stop and bump and grind some.
Also noticed there is not some clicking sounds when its printing that was not there yesterday.
Is this an adjustment you can make in the profiles?Last edited by bombnav; 03-25-2016 at 01:01 AM.
03-25-2016, 03:47 AM #698
- Mar 2016
- 14
hi , im new here,
may i know what are the differences between flashforge creator pro against qidi tech
other than price ?
which is more reliable to pay for ?
guide me thanks !
03-25-2016, 07:39 AM #699
Congrats!
You can adjust he height of the nozzles. I haven't had to do this yet so I'm not sure where the set screw is, but it shouldn't be too hard to find.
1. Level your bed against the lower nozzle.
2. Level your higher nozzle against the bed.
Here is a discussion about this for the Flashforge:
http://3dprintboard.com/showthread.p...-across-prints
Here is a video for the Makerbot:
https://www.youtube.com/watch?v=yBVUJpY2YX4
From those you should be able to figure it out.
Is this while everything is heating up, or when it starts laying down plastic?
Try unloading the filament and then reloading it.
03-25-2016, 07:43 AM #700
I think the main difference is the Flashforge has 10mm rods on the Z-Axis and the Qidi has 8mm. You get more wobble on the Z-Axis platform on the Qidi. Hopefully this is something Qidi fixes in the future. Also it is something you can upgrade on the Qidi. (Being an Engineer that's what makes it fun for me)
As for reliability, they are both pretty similar. The main parts are the same or very similar between the two units.
New member with print issue
Today, 08:57 AM in Tips, Tricks and Tech Help
