Thread: AutoHome vs ABL Z axis Height
03-06-2016, 06:14 PM #1
Hi, Using the beckdac / Marlin code, if I do an AutoHome and then move the Z axis to zero the nozzle is 4.1mm above the glass. If I then do an ABL and move the Z axis to zero the nozzle is exactly where it should be.
I am assuming (probably a mistake) that the configuration.h value Z_PROBE_OFFSET_FROM_EXTRUDER is used for both ABL and AutoHome? Is there another value that would affect AutoHome but not ABL that could cause this discrepancy?
03-07-2016, 07:04 PM #2
- 134
Follow the section here about calibrating the Z offset - http://clough42.com/instructions/marlin-firmware-setup/
03-10-2016, 10:06 PM #3
Thanks kd7eir, I used that reference to set up the ABL, and it works very well. Where my problem arose was when I selected AutoHome from the menu. This gave the 4.1mm discrepancy I was talking about.
03-11-2016, 06:20 PM #4
- 134
If I auto home from the menu my hotend ends up in free space as well, but when I start a print the Z offset in Marlin lowers it to the correct clearance from the bed.
03-13-2016, 08:14 AM #5
Thanks, it seems I either have an incorrect or no value in the Z offset. It appears that this Z offset only applies to Auto Home and has no effect on ABL?
Could you give me a clue as to where I can input an offset value?
Thanks
