Thread: Tangled mess of filament
02-26-2016, 01:14 AM #2
- Feb 2016
- 12
I may have solved my problem. When I carefully looked at everything and watched the printhead moving it seems like one half of the printer was not working properly and of course the rest of the crew. I examined the bed for level mess it up. One side was slightly lower than the other. I took everything apart and cleaned the nozzle, Took the print bed bath and cleaned the build tack. In fact I took the tag off and put an entirely new sheet on it and replace the bed. Still not working properly so I took the bed off again to see if there was anything causing the unevenness. Apparently I had put the plate in words and it of course did not seat properly. When I discovered the proper way to insert it it also solve the problem of why I could not lift the print bed easily. My advice to anyone else having a similar problem is to examine everything that is going on very carefully. I am now running a print that's at least started out looking good and I am crossing my fingers.
