02-25-2016, 08:18 AM #2
I've found any Easy way to determine strength of filament, before printing,
is just bend it slowly to 90 degree bend and see if it breaks.
(less than a Inch of filament is used per test )
I use a bench-vice to hold the free-end of filament, so bend angle will always be the same.
If it survives to 90 deg then it's Good filament !
Note: some spots in same spool break sooner and easier than others,
so need to do this test several times to get good indication of Overall strength
And ABS usually breaks easier than PLALast edited by EagleSeven; 02-25-2016 at 09:17 AM.
