03-01-2014, 02:23 PM #1
- 84
Printers at the attic / changing temperature
Hello,
at the moment, I've just 1 printer and 1 scanner.
But, within a fe months, I've got more printers and more scanners.
I've to decide to put them at the attic in stead of the room where they stand now. Because i don't have much room to place them in the room where they stand now.
But, there is a little problem.
In the winter its a bit colder there and in the summer it can be around 30 / 35 Centrigrade.
Can that be a problem for the printers and for the printquality?
What can I do to the print quality wenn its getting warmer inside the attic?
Thanks a lot for your answers.
Gr. René
03-01-2014, 03:11 PM #2
Are you storing them in the attic, or printing on them up there? Most build materials are sensitive to temperature and moisture.
03-01-2014, 04:34 PM #3
- 84
03-01-2014, 06:22 PM #4
I've been printing in my workshop where the temperature has been 30 - 35C (Australian Summer). I think that these ambient temperatures may have contributed to corner lifting. All I can suggest is that if you are working in an attic, set up a cooling air-conditioner, but be careful about humidity. A small portable unit should do an attic space. If the temperature gets above 25C, try doing ABS prints with the print board at 90C.
Old Man Emu
03-02-2014, 07:32 AM #5
If your using heated platforms, as long as you close the print envelope, it wont matter much..
03-02-2014, 07:36 AM #6
If your that worried baout it, maybe consider putting a space heater up there or somethin...
Design not printing solid
09-17-2024, 06:12 AM in 3D Modeling, Design, Scanners
