Thread: Cleaning the bed in aceton
03-01-2014, 02:27 PM #1
- 84
Hello,
at the moment, I've got an up! plus 2 printer at home and I print with ABS on it.
Now, my previous bed I put on it, is full with ABS material.
They told me, to clean it in aceton.
What is the best way to clean it in?
I mean, If I put it in a plastic box, does that plastic box disappear because of the aceton I put on it? So, do I need a glas box? Or what type of box can I use for it?
And another question:
What do you do to clean your bed?
Thanks!
Gr. René
03-01-2014, 03:10 PM #2
I use a razor blade. I dip the bed in warm water to wash the hairspray off.
03-03-2014, 01:32 PM #3
- 84
How do you do that then?
03-03-2014, 03:37 PM #4
When in hot water the hairspray will stick less, But will be anoying to get off with your fingers,
So its easyer to use a piece of metal to scrap the hairspray off when in water/just out of hot water.
03-11-2014, 09:08 PM #5
- Mar 2014
