Results 1 to 10 of 16
Thread: Auto bed level
01-30-2016, 05:05 PM #4
- Dec 2015
- 24
Okay, that *would* suck.It depends on your slicer, basically. With Slic3r, I just put my ABL commands in the "Start G-Code" section for the printer. However, that section isn't run until the heatbed is at temp and it's started the hotend warming up.I assume you're either not using Slic3r or perhaps an older version (I'm on 1.2.9), so you'd have to work out the right place to add ABL commands in your slicer. Assuming it's even possible.
