Results 1 to 9 of 9
01-28-2016, 09:09 AM #1
would like to get some thought on this idea.
I got my DaVinci 1.0 way back in August of 2014 and used it almost non stop till February of 2015 when I go my Flashforge Creator Pro. Since then I don't use the DaVinci as much. I was thinking about modding it and replacing the motherboard with a Mighty Board
http://www.flashforge-usa.com/shop/part … board.html I know I will need to replace the end stops and the hot end. But I should be able to use the stepper motors. I will also replace the heated bed with a better one. I would like to install the Sailfish firmware on it.
Just wandering if this will work or would it be a wast of time?
01-28-2016, 09:37 AM #2
- Burnley, UK
- 1,662
Marlin is much better for custom machines.
01-28-2016, 09:44 AM #3
01-28-2016, 12:44 PM #4
sounds like a good idea. Why would you move the end stops, or replace the hotend ?
If they have the same board connectors and plug into the right connectors - why wouldn't they work ?
01-28-2016, 12:48 PM #5
- Burnley, UK
- 1,662
You may be able to get Marlin running on a mightyboard but as you are replacing the motherboard you would do better getting an arduino, it is about 1/4 the cost.
01-28-2016, 01:08 PM #6
01-28-2016, 01:09 PM #7
01-28-2016, 01:09 PM #8
- Burnley, UK
- 1,662
Marlin works with optical senses jsut fine, both my CNC PCB cutter and my laser cutter have optical endstops and RAMPS.
01-28-2016, 01:18 PM #9
