Results 11 to 20 of 39
01-19-2016, 10:39 AM #11
- Jan 2016
- 31
01-19-2016, 01:20 PM #12
- Jan 2016
- 121
I did a almost a year ago....but basically I removed the BBB, attached a serial port between it and a computer, and was able to get access to the console and used the boot manager on it to look at the file system and files on it, PITA. I'm guessing they'll patch things up if they can if they find out people are exploiting things. I'd be interested in getting more info on what you used to get into the machine.
01-19-2016, 05:06 PM #13
- Jan 2016
- 31
01-20-2016, 08:52 AM #14
- Jan 2016
- 121
01-20-2016, 09:21 AM #15
- Jan 2016
- 31
Well, the ssh tunneling is going to take days. It did 80 ports with 5 attempts each and that took 6 hours. It's some sort of brute force attack program. It tries a port on the ip and I assume it attempts 5 different passwords. I did an open port scan though and really 22 is the only one that shows the ssh protocol, there are several others that are open, but nothing displays, also when I try the tunneler on them nothing appears to happen. Last night I tried the serial method and was able to see it boot, I have yet to poke around. There is still two other methods left to try and crack this nut if these current methods don't work.
01-20-2016, 01:06 PM #16
- Jan 2016
- 121
What are you trying to crack? The password? If so based on John The Ripper, I have it, but it won't let me login via that user name/password via ssh on port 22. I will need to get my setup back up to try it out.
01-20-2016, 01:14 PM #17
- Jan 2016
- 31
01-22-2016, 08:55 PM #18
- Jan 2016
- 121
HOORAH! I got in. Will post details in the next few hours or so. I need to confirm if I got lucky (after I add a backdoor).
01-22-2016, 09:55 PM #19
- Jan 2016
- 31
Awesome! Great work.
01-23-2016, 06:28 AM #20
- Jan 2016
- 121
Printing time- Is this right?
