Results 51 to 60 of 84
01-17-2016, 05:59 PM #51
01-18-2016, 07:10 AM #52
Flashair info..
http://elm-chan.org/junk/fa/faff.html
01-18-2016, 07:35 AM #53
Nice little utility.
http://dotnet.work/2014/09/flashair-...r-for-windows/
01-19-2016, 07:04 AM #54
01-19-2016, 07:44 AM #55
02-03-2016, 06:07 AM #56
I just purchased another Flashair card from Amazon (32G Type III) (Getting ready for a new 3DPrinter) and again had absolutely no problem with connecting to my network or mapping it to my Windows 10 machine.
If it helps, these are the steps I performed to get my 2nd card running.
1) The first thing I did was copy the files and folders from my existing card onto my desktop.
2) Ran the configuration tool on the NEW card, (I just let it fail on the hard drive setup -- no need for it), and set up the WiFi (See Pic)
3) Opened the CONFIG file on the NEW card and recorded the CID.
4) Opened the CONFIG file on the COPIED files and folders from my existing card and changed the IP Address to an unused address on my network and change the CID to the new cards CID.
5) Coped all the files and folders to the new card.
6) Ran the WiFi configuration tool on the NEW card again.
7) Rebooted my router and viola, after about 5 min I was mapping the new card.
05-16-2016, 01:17 PM #57
06-09-2016, 07:08 AM #58
- Jul 2014
- UK
- 124
I have an 8GB W-02 card.
Does this only work with a W-03 card ?
06-09-2016, 08:52 AM #59
06-09-2016, 09:26 AM #60
- Jul 2014
- UK
- 124
I did try using your guide but couldn't get the card to connect to my router.
According to this https://www.toshiba.co.jp/p-media/ww...ive_webdav.pdf the Flashair drive option only works with W-03 cards.
When I ran the Flashair tool, the Flashair drive option was greyed out so I guess W-02 cards are not compatible.
I can still ulpload to the card by connecting directly to it and using the browser mod however.
