Results 1 to 10 of 84
01-10-2016, 08:55 AM #9
The printer's firmware will accept .stl files, from slicer, if sent thru USB, but will Not from SD.
( I only know for sure about the CTC printer, I assume other similar printer makes are the Same)
.stl now seems to be the Standard file type,
and if you are Forced to first convert all .stl files to .3xg files,
before sending them to printer,
I would call that a 'Limitation' !Last edited by EagleSeven; 01-10-2016 at 09:12 AM.
