Results 1 to 8 of 8
Thread: x-axis motor problem?
12-23-2015, 10:15 PM #1
- May 2015
- 43
a couple minutes after the print starts it jumps all around. Would it be the motor that is bad?
https://www.youtube.com/watch?v=Ij8IN0S575E
12-23-2015, 11:54 PM #2
- May 2015
- 43
anyone help??
12-24-2015, 12:12 AM #3
- Burnley, UK
- 1,662
I think you are printing way way too fast. More info is needed such as "it used to work" or maybe "I have just built it" or "it worked for a while till the dog p^^^ed on it" etc etc.
Put more effort into your question and people will put more effort into the answer.
12-24-2015, 12:28 AM #4
- May 2015
- 43
It use to work just fine a couple days ago. I was messing with some screw things on the mobo and now it just says that there is a problem and that the printer shut down so I have no idea
12-24-2015, 02:00 AM #5
- Burnley, UK
- 1,662
"some screw things"
Which screw things, seems ot me you probably messed with the current settings for the steppers but until you get some explanations guessing si the order of the day.
12-24-2015, 02:35 AM #6
- May 2015
- 43
Yea it was the little screws on the steppers. How do I fix it? Thanks for the replies
12-24-2015, 10:30 AM #7
12-24-2015, 03:47 PM #8
- May 2015
- 43
Anyone? I tried using a meter and adjusitng them and it still wont work. Only the end stops and motors are pugged in
