12-04-2015, 11:20 AM #1
Love my FFCP Clone - Now I want higher Precision
Absolutely in love with my MonoPrice FlashForge Creator Pro Clone, but sometimes I want to print at a higher resolution than 100 microns for very small intricate parts.
50 microns might do the trick.
Can anyone suggest a good printer for that? Build volume can be small. PLA and PETG. Heated bed a plus.
12-04-2015, 11:36 AM #2
We've printed 25 micron layers. You set whatever layer thickness you want. PM me if you want more info.
12-04-2015, 10:13 PM #3
For what exactly? There may be an alternative solution.
Mechanically your printer can do very fine layers (down to 0.02mm) with ease. However the weak link would be the extruder stepperthat cannot turn at such a low speed. A reduction gear would be required, say, 1:10 to achieve the low output required.
12-05-2015, 11:03 AM #4
