  1. #1
    Setting print size?
    this may be a completely obvious question - but i'm a bit baffled. is there a way to set a precise print size? i've exported a model i want to print to STL, uploaded to the web site, but then there doesn't seem to be a way to manipulate it to 4cm long, for example. there only is the interface with the slider which seems super imprecise.
  2. #2
    Jul 2014
    usually with a slicer if you double click the model you can enter any dimensions, rotations manually.
    no idea how the mod-t one works. But can't see how you'd not be able to do something a sbasic as that.
  3. #3
    Spoke to support about this - They're aware of the issue, theres a slider that shows a visual approximation of size, but its very fidgety, they recommend using another slicer if you need specific sizes, e.g. astroprint.
    So my question is - How do I set size in astroprint? I've looked around but can't find any size setting
