Thread: FlashForge Dreamer
11-30-2015, 12:07 PM #1
- Nov 2015
FlashForge Dreamer
Hello everybody,
I have a flashforge 3D Dreamer printers.
Unfortunately I have problems with wifi.
I have an address range 192.168.0. ###
and now the FlashForge Dreamer has the IP 10.10.100.254
Now I have changed by software (wifi), the IP address (192.168.0.150), unfortunately I can no longer be addressed via WIFI printer.
The display from Dreamer appears 10.10.10.254:8899.
Is there a possibility to reset the Dreamer (not the small button next to the SD slot) but a factory reset where the WIFI address is reset.
Greeting Herbert
12-12-2015, 10:49 AM #2
- Oct 2015
- 12
12-12-2015, 01:51 PM #3
- Jan 2015
- 62
Hello,
Go here, http://www.flashforge-usa.com/support/downloads/
And download the Dreamer User Manual. It will tell you how to set up WIFI. You will probably have to start from the beginning and do it over again.
