Results 1 to 10 of 24
11-27-2015, 03:19 AM #1
- 219
11-27-2015, 08:24 AM #2
- Nov 2015
- 15
Thanks, I'm glad to hear that trying out other resins should be possible.
But was there any reason to choose resin with 8% shrinkage for Paechy Juice? I guess higher the surface tension, worse the resolution and quality will be. So, it would be nice to know what's the surface tension of current Peachy Juice in dyn/cm? At the moment I have no idea if official Peachy Juice is just typical resin or is it a resin with exceptionally low surface tension. If somebody could answer this I would be very grateful.
This is interesting idea, but probably software will need to take refraction into account to prevent precision loss. Some loss of precision may still happen, but if surface tension was causing more problems, overall precision may improve (or may become worse, it is hard to tell without experimenting).
