Results 21 to 27 of 27
11-24-2015, 03:55 PM #21
11-25-2015, 07:04 AM #22
Yes, I can see how the Rough surface of filament could Help it going thru extruder,
more friction at feed-gear should really help, also.
Seems to be Great layer-adhesion at 200C,
I do have it going a little slower when doing outer-walls, with a small size nozzle (.3mm).
Filament hung-up twice on this spool, so far, when it got trapped at outer edge of spool.
I like PETG Much Better than ABS !
I like Any filament Better than ABS ! LOLLast edited by EagleSeven; 11-25-2015 at 07:21 AM.
11-25-2015, 10:55 PM #23
- new jersey
- 752
you prob know this already but when removing filament from your printer NEVER let the end of the filament go. if filament gets tangled, 99.9% of the time its from the user letting the end of the filament go when removing the spool from the printer. i hear ya on the abs.
11-26-2015, 12:39 AM #24
PETG is much flexible , I print at 230 deg in nozzle, and 100 deg in heat bed.
No cracking at all
11-26-2015, 04:44 AM #25
11-26-2015, 04:48 AM #26
Perhaps this one...
11-26-2015, 07:02 AM #27
Here is what that one looks like. I just now printed the wheels, so you can see a few cat whiskers that need to be cleaned up on the wheels:
