11-18-2015, 01:29 PM #1
Avante Technology's Water Removeable Support
Avante Technology is releasing a new water soluble support material formulated to work with their FilaOne GREEN advanced industrial-grade composite filament. FilaOne Water Removable Support Material is the first water soluble support filament designed specifically for high quality engineering grade filaments on standard desktop FDM 3D printers. The printed part simply needs to be submerged in boiling water to pull the support material away, will not cause any surface texturing or burrs and the waste water and remaining material can be disposed of without any sort of treatment or specialized disposal. You can read more about this new 3D printing filament over on 3DPrint.com: http://3dprint.com/106294/avante-support-material/
11-18-2015, 05:50 PM #2
By my own experience I made, I wouldn't use this soluble support material together with PLA. Especially if you print thin walled prints. The boiling water will damage PLA and the layer adhesion will definitely suffer by this.
