11-05-2015, 12:14 PM #1
- Oct 2015
- 12
New FF Creator Pro with "Tool 1 Failure"
Hi guys, I have received a new FF Creator pro...when i have to load the filament, i can load ok on the right extruder and prints absolutely great
However when I wanted to load the left, I got the following message "Tool 1 Failre! Temperature reads are failing. Check wiring."
Is this referring to the thermocouple at the underside? one of the wires was loose, so i put it back again but the error still persists.
i have not plugged the creator pro to my computer as i use my SD card and have not had a chance to check the firmware version. would this have any effect?
See the attachment below.
Any help appreciated in advance.
Cheers
11-05-2015, 03:08 PM #2
- Jan 2015
I'm not an expert by any means, but I think that plugging it into your computer could help you get a better idea of what is going on.
11-07-2015, 04:04 PM #3
11-12-2015, 02:06 PM #4
- 441
I would contact support if you just purchased it.
