Results 1 to 9 of 9
Thread: 3D printer loops
02-16-2014, 02:04 PM #1
3D printer loops
Hey guys,
wanted to ask if you guys knew what this is and how to get it rid off?
I heard this was due a to low temp or to high?
https://www.dropbox.com/s/d4ril7ohh5...2021.03.30.jpg
Hoping someone can help me on this one ^^
Thanks guys !
02-18-2014, 12:59 PM #2
Nobody seems to know the cause of this ? :?
02-19-2014, 01:43 AM #3
- Honolulu, HI
- 199
Luigi, not sure what you are referring to in the picture. Could you try and explain what you are asking about?
02-19-2014, 10:36 AM #4
02-19-2014, 11:02 AM #5
- Honolulu, HI
- 199
Is this PLA? It could be water in your filament. I keep mine in an air tight container with desiccant. I live by the ocean so things get moist and salty.
02-19-2014, 02:28 PM #6
Well, it shouldnt,
My room isnt that moist at all, i also use a sponge filter to avoid dust.
02-19-2014, 03:43 PM #7
- Honolulu, HI
- 199
Can you hear it "POP" when you are printing? If there is water in it then it will make a little popping sound as it extrudes. You don't have to live in a very humid environment for this to be an issue.
02-20-2014, 09:29 AM #8
I dont think so?
I have heard it might be that i run it to cold or to hot tho. (The hotend)
I thought someone mentiont this in a thread once.
03-05-2014, 06:48 PM #9
Hey Luigi, I have not been 3d printing long but I have been hammering out many prints in search of the Perfect print... my suggestions on the image is as follows: - the little lumps in the print are where the 'loop' / 'layer' starts and finishes then moves up to the next leyer - the lines that i think your asking about (as you get closer to the top), is where the angle of the curve is almost too steep and there is less filament touching each other - the little stringy piece looks like it is from when the print finishes and returns 'home', the pressure in the nozzle will continue to push plastic out. I hope they help and this is not an answer from an expert, just a nooby CYA POM
