Results 1 to 10 of 12
02-18-2014, 01:25 PM #5
I did check my E axis and dimensions. The E axis was good and the dimension of the filament measured with a digital caliper is 2.98. I made that adjustment in my settings. It was driving me crazy. Changing the Extrusion rate setting for now has solved it. I'll look at the E axis again if it pops back up.
So I guess what you are trying to say is, that if the E axis is correct, the dimension is correct and the filament is consistent, I should not have to change the Extrusion rate from 100%.Bambu P1S/AMS
