Results 1 to 10 of 15
Thread: Base printing problem
10-23-2015, 02:48 AM #10
- Sep 2014
- Brummen, Netherlands
- 265
What are the dimensions of that object? With ABS and very large objects you will either get warping or cracked layers.
I have found that 3DLac on glass gives me excellent bonding results for ABS, PLA and PETG. Just spray it on before you print and away you go...
Also, make sure your bed z-height is calibrated well. If the distance is a bit too much the first layer will bond poorly whatever you do.
