Results 1 to 10 of 13
09-21-2015, 06:00 PM #1
- Apr 2015
- 25
Smaller nozzle size, where to buy?
Many thanks to all who responded to my last question about nozzles. I've been out of commission with eye problems.
Now I need to know where to purchase smaller nozzles, .1, .2, .3. that will work with my FlashForge "Original" extruders? These extruders have the smaller teflon tubes inside them and the metal outer tube DOES NOT have threads. I do not have the "Newer" versions.
I don't see them listed on the FlashForge web site.
Again, any help is greatly appreciated.
Don
09-21-2015, 06:27 PM #2
I think you can buy on this link. You can also find it on Amazon or eBay if you want. Hope this helps!
09-22-2015, 06:48 AM #3
- Apr 2015
- 25
Bobby,
I checked it out and it looks like they only sell the .4mm nozzles. I'm looking for smaller ones but thanks for your reply.
Don
09-22-2015, 01:22 PM #4
I found Set of nozzles on eBay , for our CTC printer,
which I think is same thread size ?
Set included 2 each of .2 .3 .4 & .5mm sizes
They did Not cost much.
Don't remember seeing any in .1mm size,
which I think is Too small anyway.
We found that .3 or .4 size is best for our printer.
We also found a set of drill-bits, in those sizes, to measure the nozzles accurately
09-22-2015, 01:53 PM #5
- Apr 2015
- 25
Bobby,
Can you re-send the URL for smaller nozzles via email? I can't find any attachments/links on this site.
donperla@att.net
Thanks,
Don
09-22-2015, 01:57 PM #6
- Apr 2015
- 25
EagleSeven,
Can you send the URL/auction site via email?
donperla@att.net
I can't find any attachments/links on this site, I must be doing something wrong.
Thanks,
Don
09-22-2015, 08:15 PM #7
Hi Don!
Sure! Will send it to you in a minute.
09-23-2015, 08:15 AM #8
09-23-2015, 12:31 PM #9
- Apr 2015
- 25
Yes, thank you. I will be in touch.
Don
09-26-2015, 02:22 PM #10
- Apr 2015
- 25
After checking several leads I still can't find the correct .2 or.3 nozzles to fit my "orignal" Mark 8 extruders that came with my CTC printer.
The problem seem to be the size of the INPUT hole, it has to accept the smaller (orginal) teflon tube and have M6 threads.
I asked two sellers on eBay but they did not respond....go figure !
If any one has any more leads please let me know.
A manufacture of quality high performance nozzles emailed me and mentioned that the "old/original" are obsolete and are being replaced by the new ones with the larger hole & teflon tube. This means I may have to change both extruders to the new type if I want a smaller nozzle size.
Don
