Results 1 to 8 of 8
Thread: PSU for Prusa i3
09-10-2015, 06:23 PM #2
- Jan 2015
- 36
its quite common to use a computer power supply my first I3 used one. 400W should be the minimum .. you should also use load resistors to increase and stabilize the maximum output of the power supply also allegedly some PSU's will shut down if there is a high load on the 12v rail's and no load on the 5v rails.
