Results 71 to 80 of 83
Thread: Bonded Heat bed for 12"
09-02-2015, 02:59 PM #71
- Feb 2015
- 211
09-02-2015, 03:04 PM #72
- Nov 2014
- 138
Thank You!!! Hope this helps you greatly. And those upgrade you meaning on doing. Will truly helps when you get there.
09-02-2015, 03:08 PM #73
- Nov 2014
- 138
Wow I get your frustration is you were getting prints like that. Hope this takes care of all those layer problems. And the sound of it if it was because of the heatbed this should help out alot. And now that you say it. I think is the 6mm thick glass that is helping me with those kind of print. Reason is when I have my heat bed temp at 110 I can see it bow below my glass.
09-02-2015, 03:17 PM #74
- Jan 2015
- 68
I had this same exact issue with my 12" and found a quick solution was to shim up the middle of the bed with cork to remove any room for warping. Not the best solution since it made leveling much more complicated. So I am very excited to see your results and can't wait to try it myself. Great job Chadd!
09-02-2015, 03:46 PM #75
- Feb 2015
- 211
Here is the thread on PID setup.
http://3dprintboard.com/showthread.p...7322#post67322
09-02-2015, 04:17 PM #76
- Feb 2015
- 211
You enter them in your Configuration.h file. You also need to enable PID for the heat bed. I started a separate thread on the PID setup.
09-02-2015, 11:21 PM #77
- Feb 2015
- 371
So I think I too will be making the ssr switch. While I am at it I also think my power supply may need an upgrade. What are you using?
i did not get the unit called out from open builds as they were out of stock. My supply came from Amazon. As stated before, my voltage has drastic swings when the bed kicks in. I'm thinking instead of two supplies I may just get a 40 amp power supply.
09-02-2015, 11:31 PM #78
- Feb 2015
- 211
I am using a supply that i got from amazon, this is the unit I got
http://www.amazon.com/gp/product/B00...rch_detailpage
09-04-2015, 07:07 AM #79
- Feb 2015
- 371
Have you checked your voltage at all?
09-04-2015, 10:44 AM #80
- Feb 2015
- 211
