Thread: solid layers issue....
08-31-2015, 08:54 PM #1
- Aug 2015
- 12
when I print my solid layers have gaps. see pic
setting for print
infill %10
layer height .27mm
shells 1
feedrate 100mm/s
travel 120
temp 205
what will make solid aesthetically pleasing layers
09-01-2015, 12:55 AM #2
09-01-2015, 07:04 AM #3
Were you around when the first layer was made ? Did you notice some clicking noises ? You say 205°C, I assume you print PLA ?
Anyway, if it is not a mechanical issue as asked above, some other factors would clearly help :
- Try and divide by 2 the printing speed, see what happens.
- You seem to be under-extruding, so 1/ measure that your filament is actually at whatever it is supposed to be (1,75mm or 3mm)and if the value is correct then 2/ try to run a check on your extrusion rate. There are tutorials online in the reprap forums.
- With a 10% infill you might have issues on the topmost layers even if not underextruding. For that reason I would advise to have 3 layers on the top : that helps a bit when you have low infill %.
09-01-2015, 09:07 PM #4
- Aug 2015
- 12
yes I am printing PLA and yes there is a clicking noise (it sounds like slipping filament) plus when printing also my filament measures out to 1.61mm and my gcode was set to 1.82mm I dropped it down to 1.75mm and I am testing a slower print speed I will post results
09-01-2015, 10:16 PM #5
- Aug 2015
- 12
I watch a print very closely and I am definitely have filament slippage because as I watch with every click sound I can see the extruder momentarily stop extruding and then continue leaving the gaps how do I stop filament slippage?
09-01-2015, 10:44 PM #6
- Aug 2015
- 12
Okay so I got it working pretty amazing now.I leveled the bed, manually fed PLA through the nozzle to clear it, then I unloaded and reloaded the filament the I went from 205°C temp to 215°C and now its perfect So it was either clogged or printing to cold
09-02-2015, 01:35 AM #7
