Thread: Watertight Vase
08-22-2015, 12:18 AM #1
- Feb 2015
- 29
Watertight Vase
By watertight I mean this part will hold real water and not leak. I have printed several vase-like parts before, and they all leaked when I put water in them. This makes such parts far less useful than if they were water tight.
This part has double walls - not counting the spiral ribs which are really just decoration - and each wall is made with 4 loops. The bottom is also double walled with each surface made with 4 layers.
This photo
shows what a layer height of 0.300 mm looks like. Normally I use 0.200 mm, but I wanted to see if increasing this as a way to reduce total print time would be OK. The final result is not as good as 0.200 mm, but I still think it is acceptable.
I used Craftware to slice the part, after running the original STL file through 3D Builder to correct errors. (The previous version of Craftware would not slice this part properly - thanks to Janos for the current set of updates.) Total print time for this part was 11 hours 11 minutes. If you want to print this yourself you can find the STL file here
https://pinshape.com/items/8200-3d-printed-watertight-spiral-vase
or here:
http://www.thingiverse.com/thing:978836
