Thread: E3Elite6 ptfe liner slipping out
08-20-2015, 06:43 AM #1
- 349
Anyone have this problem, where the ptfe liner slips up and out during retractions? The little black ring/collet is supposed to keep the liner down and in place, but the liner slips up through it anyway.
08-20-2015, 10:03 PM #2
- May 2015
- 39
Mine works fine.
08-21-2015, 05:19 AM #3
- 349
Well the solution was to melt the top part of the passage closed where the liner goes though, then drill a hole just big enough for the filament only. This keeps the liner down.
08-21-2015, 12:13 PM #4
- May 2015
- 39
You could probably replace the Bowden coupling.
http://www.smw3d.com/e3d-embedded-bowden-coupling/
08-21-2015, 02:48 PM #5
- 349
Well I did already order some, but this was after I figured how to seal the top of the passage. Nevertheless, the coupling I had was new, and was not doing the job, so I'm not sure another new one would be better.
New member with print issue
