Results 1 to 8 of 8
Thread: Can I solder PSU wires to RAMPS?
08-20-2015, 12:26 AM #1
Hello all,
So recently I added a heat bed to my Delta and because of that the RAMPS board started smoking and I noticed that the 4 pins terminal where you connect power to is melted. Here is an image:
So I want to solder the wires to the pins on the board because I can't wait until my new terminal comes in the mail. Would this work or catch my printer on fire?
Cheers.
08-20-2015, 12:53 AM #2
- Aug 2014
- Montreal, Quebec
- 576
Ramps 1.4 I assume? They are notorious for frying high current. Also do bundle more wire together (4-5), the 18Gauge alone is not enough to handle that much current and will just heat up.
Also, as long as you know what you're doing you can solder fine.
08-20-2015, 01:01 AM #3
08-20-2015, 07:36 AM #4
08-20-2015, 11:02 PM #5
- Aug 2014
- Montreal, Quebec
- 576
So the problem was on your makerfarm or the delta?
08-21-2015, 04:36 AM #6
08-22-2015, 11:27 PM #7
- Aug 2014
- Montreal, Quebec
- 576
Just to make sure, you also bundle the negative also right?
08-23-2015, 01:18 AM #8
